is there a way to put pbr materials from grasshopper?
You can use @ShapeDiver plugin, but the display component doesn’t support Roughness, Metalness, Bump even Normal.
I would also appreciate the ability to see the rendered viewport result with the support of mentioned maps above.
@Jonish Can the Vray plugin in GH show PBR in the preview?
Hey guys, Miguel, are you trying to preview Grasshopper geometry in Rhino rendered view as previously created PBR material (i.e. gold, plastic, …) or do you want to use Grasshopper to generate tens or hundreds new dynamic PBR materials? Both should be possible.
Cheers
Jonas
