MatchSrf doesn't match to curve
Hello
I’m using the Rhino BETA and have just encountered an issue matching surface edge to a floating curve, using MatchSrf.
I can select the surface edge and then the curve when prompted, then the command line requests to ‘Select target surface’. As there isn’t a target surface in this case, I click enter and Rhino exits the command without committing the task!
MatchSrf issue.3dm (86.5 KB)
Just installed the latest BETA and it works!
This works with History now too!
Brilliant!
