Can’t post a screenshot of a sequence of actions. How about this:
Run MatchSrf
Select a surface edge
Switch to OnSurface=Yes
For no very good reason you now have to right-click
Select the surface you wish to match onto.
That bold line is something that I think easily could be eliminated, unless there’s a very good usability reason why that extra right-click is there (I won’t buy a technical reason).
When it’s relevant. Ie, then OnSurface=Off… that’s my whole point, once OnSurface is turned on I don’t have a curve to match to do I? The tool should automatically recognize this and switch to surface picking instead.
OnSurface=On is only needed for an extra curve.
OnSurface =Off works without too extra clicking.
That’s right, there’s no extra action.
The default tool is to choose a surface, you don’t need an extra click.
I checked rhino 7 WIP 7 and Rhino 6. Everything works as I’ve described before.
On 7 WIP filmed the plot of how it works.
If you need a story on Rhino 6, too, I can shoot a story, it works absolutely like 7 WIP.
I’ve never done this (obviously). Is it a common workflow in Rhino?
I ask, because the most common workflow should be the default setting, and the less used should be the one requiring an extra click. Although with that workflow existing, I guess you couldn’t do a Yes/No option like there is now, but rather a Curve/Surface/Combo… which is what it really is.
EDIT: Btw, your first video… it looks dangerously like the curve is projected and not pulled onto the surface… I really hope that’s not the case?
Here’s a story from Rhino 6, the most common default workflow.
The first click of the LMB is the first edge.
The second click of the LMB is the second edge.
You can tell where the extra click of the LMB or RMB?
