Match Text Filter - RegEx mode anchors aren't working for Model Layers?
I’m using the Match Text Filter component and it looks like the text anchors $ and ^ are not registering when filtering for a Model Object Layer.
Similarly, if I use the End With mode on the Contains Text Filter component, the output for the filter is empty. So I cannot use either methods to filter out nested layers.
R9 WIP (9.0.25252.12305, 2025-09-09), Windows 11.
In the first screenshot on the Match Text Filter, what did you set in the Key input?
It is set to Model Object > Layer.
Try to set this to Layer.Path
Test Curve.3dm (35.0 KB)
Regex anchor filter.gh (23.3 KB)
I see the path option now further down the list. I’ve been using the Layer option before and apart from this irregularity it had been working fine. Thanks!
I find the Key options a bit finnicky. Also it does not parse text panel input which I think would be a nice addition…
Yeah that’s what I immediately noticed when trying your suggestion. :sweat_smile:
