Match line with text
Hi Guy,
I have Floor beam plan show the center line and label with schedule beside (height and width)
How I can auto match center line with label and profile in schedule
Match Line with text.3dm (73.0 KB)
Thanks All
Anyone have idea to help me!
Thanks
Here i found the nearest text and apply it as a name and attribute to the line.
Thanks @Japhy
It work fine, and next how I can extrude these curve after match Name in Rhino.
The profile will be match with Name and schedule beside
Extrude Along patch, profile is rectangle
Example B1 is 250x600
This python script was on the forum. It requires you reference the linework and create a csv table.
Elefront req’d
Re_Match_Line_With_Text_Schedule.gh (10.6 KB)
To add a rectangle I added a height attribute to our line, referenced and constructed from the Lines points and our new attribute.
Re_Rect_from_Data.gh (11.1 KB)
Hi @Japhy
I will extrude line as below is example but not correct with schedule
Profile will be match with Name in Rhino, and Name will be match with profile dimension in layer Height and Width in Rhino.
Ex: Line have name B1 will be extrude with profile have Name B1 and B1 will match in schedule
I just make something but it maybe not working correct
