Auto-align text
auto align text by border?
Uploads did not work…
Do you have a solution for this work?
Hi -
You might want to explain in detail what you are trying to do. I see the picture but don’t know what it means.
If you are looking to align the text centered in between the two longest sides, I suppose that is indeed possible (assuming your shapes are all similar). As far as making the text bigger when the space is bigger, I suppose that is also possible with a bit more work. Given the holidays and the stuff I already have going, I would not be able to look at this for another couple of weeks…
Scaling text in a curve can be done in Grasshopper using EleFront:
If the text width is larger than the width of the curve, the height is adjusted accordingly.
text_resize_to_width_elefront.gh (20.4 KB)
text_resize_to_width_elefront.3dm (32.5 KB)
