MatCap + Bobi X8 = High quality Viewport
  • You can find tons of MatCap on the internet.
  • Create custom material in Rhino, Assign the MatCap only to the Environment.
  • Use Custom Preview to choose the Rhino materials in GH. No need to bake.
  • Use Bobi viewport mode to improve the real-time viewport quality.
  • Split GH canvas using the pOd plugin.
The FPS is high.
Find Bobi V8 here:
Share your custom viewport modes here - Rhino / Rhino for Windows - McNeel Forum
Your example looks great! Can you share the environment map that you used on the pot?
P.S.: Do you mean Bobi X8.ini?
Yes, it is Bobi X8.ini.
This is the png file.
00034
I download it from GitHub.
GitHub - nidorx/matcaps: Huge library of matcap PNG textures organized by color
This is the way to add it to the material.
Learned this trick from a Taiwanese teacher.
Do you remember what’s the original file name of this particular image? I can’t find its high resolution version in the link you provided above.
textures.zip (4.3 MB)
Thank you! Looks like this particular image does not have a 1024x1024 pixels version. Last night I only checked the high resolution images from your link.
I knew this trick for a while but never really understand why it works this well. I mean adding material to the environment, not color. Now you mentioned it, and I see the width is only 256 pixels, I got more curious about the principle of this. I mean 256X256 material can do nothing in modern 3D workflow, but here seems work really well… why?
High resolution images allow a smoother gradient between the colours. For example, a 256x256 pixels big environment map will limit the gradient steps to no more than 256 colours, eventually leading to colour banding.
https://cdn.svgator.com/images/2022/03/color-banding-gradient-animations.svg
Hi, I’ve posted a question that straddles this thread, and the one Bobi mentions above - here’s the question, if anyone has time to answer here or on the other:
Thanks,
Alan
