Im trying to map curves on a surface in the same way an environment map uses textures.
The curves I want to map would be exactly like a reflection map except made out of curves.
Im basically trying to create cell shading that I can use in Illustrator.
All I need to do is map a coordinate to the surface normals. But its harder than it sounds.
Environment Map.3dm (225.4 KB)
