Making a srf/solid from curves
Hey,
I am trying to make a surface or a solid out of this curves,
but no matter what i try i can’t make it work.
any clue what might be the problem?
alt shape.gh (6.0 KB)
crv.3dm (83.0 KB)
your problem is in the curve construction itself - unaligned in the middle, perhaps needing a mid horizontal section and not just top and bottom profiles - you could split your curves at all intersections more precisely then choose the correct order for NetworkSrf or EdgeSrf
you are right, i fix the curves and adjusted a horizontal section at the mid point
and it worked.
thanks
