Hi
I have a script that was posted here and it was rvb file. Now I want to make it as a button in Rhino5. could you tell me how I could make this as a button in rhino??
Dim arrObj
arrObj = Rhino.GetObjects("Select Objects to slide on curve",,, True, False)
If isNull(arrObj) Then Exit Sub
Dim strCrv
strCrv = Rhino.GetObject("Select Curve to slide over", 4)
If isNull(strCrv) Then Exit Sub
Dim arrPtOc : arrPtOc = Rhino.GetPointOnCurve(strCrv, "Set refernce point on curve")
If isNull(arrPtOc) Then Exit Sub
Call Rhino.EnableRedraw(False)
Dim arrCrvPlane : arrCrvPlane = Rhino.CurveFrame(strCrv, Rhino.CurveClosestPoint(strCrv, arrPtOc))
Dim XOrient: XOrient = Rhino.XformRotation(arrCrvPlane, Rhino.ViewCPlane(Rhino.CurrentView()))
Call Rhino.UnselectAllObjects()
Call Rhino.TransformObjects(arrObj, XOrient, False)
Call Rhino.SelectObjects(arrObj)
Dim str: str = "!_OrientOnCrv w" & Rhino.Pt2Str(Rhino.ViewCPlane(Rhino.CurrentView())(0)) & " SelID " & Chr(34) & strCrv & Chr(34) & " "
Call Rhino.EnableRedraw(True)
Call Rhino.Command(str)
The following should work… The script was originally set up for drag-and-drop alias creation, so you want to deactivate or remove the lines that create the alias. Then the “Call” line will run the script in your button.
HTH,
–Mitch
! _NoEcho -_RunScript (
'comment out or remove the following two lines
'the ' is the comment character
'Call Rhino.AddAlias(Split(Split(Rhino.LastLoadedScriptFile, "\")(Ubound(split(Rhino.LastLoadedScriptFile, "\"))), ".")(0), "!NoEcho -Loadscript " & Chr(34) & Rhino.LastLoadedScriptFile & Chr(34))
'Call Rhino.Print("Alias " & Split(Split(Rhino.LastLoadedScriptFile, "\")(Ubound(split(Rhino.LastLoadedScriptFile, "\"))), ".")(0) & " added to Rhino")
'make sure you have the following "Call" line active (that makes the script run):
Call SlideOnCurve()
Sub SlideOnCurve()
Dim arrObj
Dim strCrv
End Sub
I see the Call Rhino.AddAlias and Call Rhino.Print are for loading a script or something else.I wasn’t sure if I could delete or not but now I know. cool
thanks for the reply
Hello Dale,
I have a Closed NURBS curve (Red color) which is created from “Rhino.IntersectBreps” in Rhinoscripts. However , this Closed NURBS curve can’t be oriented with a line perpendicularly. Moreover, the normal Circle (green color) is oriented well as can be seen from the attached file.
Thank you so much for your help
Lam Nguyen test.3dm (151.3 KB)
You can use this script as an example of how to orient the Red curve perpendicular to the line.
Sub TestLam
Dim strCurve, arrCurvePlane, arrBox, arrCenter
Dim arrLine, dblParam, arrLinePlane
Dim arrXform
strCurve = Rhino.GetObject("Select planar curve to orient", 4, True)
If IsNull(strCurve) Then Exit Sub
arrCurvePlane = Rhino.CurvePlane(strCurve)
If IsNull(arrCurvePlane) Then
Call Rhino.Print("Curve is not planar.")
Exit Sub
End If
arrBox = Rhino.BoundingBox(strCurve, arrCurvePlane)
arrCenter = Rhino.PointDivide(Rhino.PointAdd(arrBox(2), arrBox(0)), 2.0)
arrCurvePlane = Rhino.MovePlane(arrCurvePlane, arrCenter)
arrLine = Rhino.GetObjectEx("Select line to orient on", 4)
If IsNull(arrLine) Then Exit Sub
dblParam = Rhino.CurveClosestPoint(arrLine(0), arrLine(3))
arrLinePlane = Rhino.CurvePerpFrame(arrLine(0), dblParam)
arrXform = Rhino.XformRotation(arrCurvePlane, arrLinePlane)
Call Rhino.TransformObject(strCurve, arrXform, True)
End Sub
