Make polyline segments even integers
You can replace item from even to odd number
round_help_extra4.gh (18.9 KB)
It works!
Thank you very much, Seghier! :slight_smile:
Now that I have your attention, maybe you could answer this small data question, so I can automate the boxes instead of an index slider:
How do I take the numbers from a list (in this case, where the value equals 1) and input these numbers as index?
It should be so simply, but I can’t for anything in the world understand how to do it. Neither Item Index or Member Index seems to work, but I might be using the wrong.
EDIT: WELL, never mind. It DID work with member index, I was just too slow to understand the output. Thanks again, Seghier, you saved my day :slight_smile:
You can use member index and replace items together
and if you have different number use the same method with a little improve
ARH, well, another thing taught! :smiley: Thank you so much, it’s beginning to make sense!
