Cplanes can be a bit confusing for me, but for a plugin I use I need to master them. I would like to make a button (or buttons) to rotate the cplane in different increments of different directions.
Someone I know gave me a tip of ('_CPlane _Rotate 0.0.0 10.0.0 45) for one of the macro commands, but that also doesnt seem to be working. The -45 is not recognized
I did not. Youre my hero.
Could you please tell me where i can find a “map” of the coordinate system in rhino so I can see which of the 0,0,0 0,0,0 I have to adjust?
Really excuse my ignorance as you can tell im new to this
coordinates are x,y,z and the 45 is the degree of rotation. so why are there 6 coordinates. 0,0,0 0,0,0
Each set of three numbers represents an X,Y,Z coordinate of a point. The command requires two points to determine a line which will be the axis about which the CPlane will rotate. As specified above, the coordinates are in the active CPlane coordinates. The macro above will rotate about the X axis.
