Maintain Relative Geometry While Dragging Along an Irregular Curve
I have an ellipse quadrant on the end of a base curve, the base curve makes two soft 45 degree bends, equaling 90 degrees. I want to drag the ellipse quadrant along the base curve through the two 45 degree turns, and have the ellipse morph, maintaining geometry relative to the base curve. I already am able to drag the ellipse quadrant along the base curve, while the ellipse quadrant origin, stays tangent to the base curve. I don’t understand how to maintain relative geometry between the ellipse quadrant, and the base curve. Thanks.
Dear Tedison,
Help us, helping you. Provide images and more important the .gh file .
Regards, Eef
Hi Eef. Thank you for your reply, and sorry for my delay.
Curve Controlled Curve V6.gh (31.6 KB)
I need the ellipse quadrant (eq) to morph in relation to the reference curve (rc), while maintaining relative geometry.
Hello Tedison,
Please internalise the curves etc, before uploading. Now they are “empty”.
I had them internalized. It’s because I didn’t include the Rhino project. I won’t supply that.
you do not need to include your rhino project.
Right click on the orange component, select internalise, and only that specific object is included.
Ok I will break it away from the whole project.
I appreciate you taking your time for this Eef.
Curve Controlled Curve V6.gh (32.5 KB)
Curve Controlled Curve.3dm (38.8 KB)
Dear Tedison.
I studied your file. And sorry, have no clue what you want to achieve.
I have to study the flow component myself to get a better understanding.
Regards, Eef
As the ellipse gets dragged into and around the bend, i need it to push away from the bend in order to maintain the geometry of the ellipse, relative to the curve it is riding on. Call it a dynamic venturi. Not sure if that helps.
Either Flow doesn’t work for this, or I set it up wrong. I’m rather new to Grasshopper.
Flow is more about warping geometry to your curve.
You should draw a sketch of what you want.
Hi Eddard. What you are showing is not far off from what I am looking for. I need the distances perpendicular from the reference curve to intersection with the ellipse quadrant, to be equal as the ellipse quadrant is dragged around the corner. Hope that makes it clearer.
It does not. An ellipse quadrant is a full 90 degrees. Please draw what you are after on a piece of paper, and photograph it with you mobile phone.
I already drew it in Rhino. How could paper be better?
Alright, but then it is still not clear what you are trying to do. Are you essentially trying to fillet a corner with two ellipse segment so that the fillet isn’t perfectly round? For this, you could use Connect Curves.
On paper you can show how it should actually look not what it is failing to look like, as in the Grasshopper file. Or is this:
exactly how it is supposed to look like?
I hate paper)) Or maybe paper hates me. Please read this again: “I need the distances perpendicular from the reference curve to intersection with the ellipse quadrant, to be constant as the ellipse quadrant is dragged around the corner”. I changed one word, perhaps for clarity. So, as I drag the ellipse base point into the bend, the ellipse will push away from the bend down and to the right, always maintaining geometry relative the main curve. Relative geometry. The ellipse referenced to the curve. A Venturi with a corner. The length of the major axis of the ellipse must remain constant. as it ravels along the main curve.The key word is certainly Venturi.
What I have here is the ellipse base point stays tangent to the curve and rotates through the transition. That’s as far as I could get.
A venturi that morphs geometrically accurate through a bend or two.
