I have generated data for a simple steel column that I use in the adapted example provided by Proven Ground. I get the error message in the ML component “1. Solution exception:De index ligt buiten de matrixgrenzen.” (index outside matrix boundaries)
Anyone have a clue what is wrong ?
I didn’t open your file since I don’t have the plugin installed, but try check for different lists having different lengths which needs to be the same length. That’s a typical cause.
Thanks for the tip; I checked and the list “train L_cr+N_Ed” has 636 items and than the “train kg/m1” has also 636 items which I expect is exacly the same length. Or is this list too long ? Is there a maximum of say 200 values ?
