Is there a way in grasshopper that we can loop through a set of operation…But with unique value at each iteration
for example- I want to loop the function “ADD”
and number of times to loop could be a number slide or variable input - (let’s say 4)
start data is - lets say 0
Now I want the program to ask user each time the number to be added
So function I want to achieve looks like (in Python) -
sum = 0
while x > 4 :
y = raw_input(“next number to add”)
sum = sum + y
x = x -1
print sum
Using plugins like Anemone or hoopsnake only allows me to do
sum = 0
while x > 4 :
y = 4 //Some constant transformation
sum = sum + y
x = x -1
print sum
So, this was just a simplified example…
The operations inside the loop could be move/rotate/or something complex
But for every iteration I want the user to decide the value for move/rotate than a constant
