Looking for help creating a parametric panel in Grasshopper
Hello everyone,
I’m a beginner in Grasshopper and I’m trying to create this type of parametric panel.
My goal is to build a script that lets me control several parameters, such as the gradient, the panel width and height, and the side lines located in the middle.
I’ve already started working on a script, but the result is still not quite what I’m aiming for.
If anyone could point me in the right direction, suggest a method, or recommend which components to use, I would really appreciate it.
Thank you in advance for your help.
MONTAGE PANNEAU GRASHOPPER.ghx (490.7 KB)
V Pattern v0.gh (52.8 KB)
Plugins: Flexibility, Clipper
Thank you very much for your help. It is quite complex for my level, but I will take the time to carefully analyze your solution and understand it as best as I can.
