Loft documentation (SplitAtTangents)
Is the SplitAtTangents section correct in the documentation for the _Loft command?
If I am not mistaken, should it not read like this instead?
"If unchecked, the loft creates a single surface.
If checked, the loft creates a polysurface when the input curves are joined tangent curves. Faces in the resulting polysurface correspond to the tangent sub-curves in the input curves."
@Gijs
can you please assign someone to fix it ?
Probably @KelvinC
thanks
DOC-403 SplitAtTangents in Loft help files
The _RailRevolve documentation has the same error @KelvinC.
@AMG
Fixed in both commands. Thank you.
