I’ve been trying to use VA Professionally for a while now,
and it is getting better and more stable in each update,
but,
i have a very big problem lately,
walls are slightly moving after i locked them, save and reopen the file,
this happened to me several times, and it is a big issue for me,
i’m attaching a file which this issue occurs,
May have something to do with walls on an upper level
Hi, after checking your file, I can see the model is really far from the origin coordinates, and this may be causing that issue. Try to move the geometry next to the document origin and check if this error still persists.
