Would like to know which layer a locked object belongs to.
As can not select at the moment.
Probably not ideal but you can run UnlockSelected
and select that object. The object’s layer will then be displayed on the status bar. Then cancel the UnlockSelected
command.
If you have long layer names and sublayers, you probably won’t be able to read the entire layer name…
Thank you @wim.
Not ideal but still better than going through layers.
Also, LockSwap
may come in handy.
