This kind of specific grasshopper plugin question should be posted on Grasshopper’s forum, in Heliotrope section. You need to register to grasshopper3d.com forum first, then join the Heliotrope group in order to be able to post a question there.
I do not have Heliotrope plugin installed, so can’t open your .gh definition properly.
Until you are waiting for the reply there, you can also check the Ladybug plugin, to analyse the number of direct sunlight hours:
Using ladybug, do you know how I could “filter” out test points that receive an undesirable # of sunlight hours in order to obtain a list of the locations and their respective # of sunlight hours?
For example: If I wanted to see only the locations that have 5 or more daylight hours in any given period of time.
It contains a custom python component. This one can also be replaced with Ladybug Branch Data component, but I find that one taking more time to load and fails with annual analysis period. If your PC is weaker as mine is, just use the component provided in attached definition. Make sure that you define the analysis period for particular period of time.
Also, I am using Lincoln, Nebraska location. You can make your own location by providing exact latitude/longitude coordinates of the actual site, by using Ladybug Construct Location component.
