Localization of Panel
Hi everyone,
I want to make my plugin as multilingual. As I watched in some tutorials how to do it in C# that all of them doing this in Windows Forms by using string.resx, string.tr.resx, string.de.resx … files for different languages.
stringresx
My plugin shaped by Panel in the Eto.Forms. Structure of plugin UI like below
MainPanel
    TabControl -> TabPages
        Collapsible Sections in the TabPages
            TextBoxes, CheckBoxes, Labels etc.. in the Sections
Is there any way to make localizable for Panel object. How can I change my Label.Text properties according to string.resx files? What is the best practices for this?
Thanks in advance,
-Oğuzhan
Hey @oguzhankoral,
You can still use .resx files with Eto.Forms. Just set the label text to the appropriate value, e.g.
myLabel.Text = strings.MyString;
Hope this helps!
@curtisw,
Thanks this helps, in addition which layer I should manage my language changes?
Where and how should I initialize this Localization, in the MainPanel? I mean, practically When I switch language from Menu, which layer should be effected according to this initialization?
Best
@oguzhankoral,
.resx files use CultureInfo.CurrentUICulture automatically, assuming you have included all of the localized assemblies. You should not have to set this yourself (it is based on the current user’s settings), but if you do want to change it via your own UI you can set strings.Culture = new CultureInfo("en-US"); for example.
Note that your UI won’t change automatically (unless you have your own code to do this), so you’d have to re-create your UI classes again to pick up the new values.
Cheers!
Hey @curtisw,
It seems issue solved! :slight_smile:
Cheers!
Hi again @curtisw,
I’ve encountered weird thing, that is when I update language by special event to take language code (en-Us, zh-CN…) I was trying to simple close panel and open again. Language changes for “Head-Up Displays” which is inheriting from DisplayConduit, but Panel inside Labels don’t change. Is there anything related to registration of Panel? Because when I open my plugin by Command typing, I register it by this code;
public MyPlugin()
    _instance = this;
    Panels.RegisterPanel(PlugIn, typeof(MyPluginMainPanel), LOC.STR("MyPlugin"), null);
The event is triggered by MyPluginTabControl which is below layer when we compare with MyPluginMainPanel. Below method is my event handler which I am using it in MyPluginMainPanel;
private void MyPluginTabControl_LanguageChanged(object sender, string e)
    System.Threading.Thread.CurrentThread.CurrentUICulture = new CultureInfo(e);
    RhinoApp.WriteLine("My Plugin language has changed...");
    Panels.ClosePanel(typeof(MyPluginMainPanel).GUID);
    Panels.OpenPanel(typeof(MyPluginMainPanel).GUID);
Do you have any clue, why it is happening?
Best
Do you have any trick about that? @curtisw
Best regards
Hey @oguzhankoral,
Panels are only created once and then cached so they can keep their state when switching panels.
You can recreate a panel’s content by setting its Content property again with the newly created content using the new language.
Hope this helps!
Hey @curtisw,
This method gave me to infinite loop as you can see gif;
loop
After your suggestion, I simply show you what code I am using in the MainPanel object;
public MyPluginMainPanel(uint documentRuntimeSerialNumber)
    DocUint = documentRuntimeSerialNumber;
    // Padding around the main container
    Padding = 6;
    // Heads-up Display
    MyPluginDisplayConduit = new MyPluginDisplayConduit();
    MyPluginDisplayConduit.Enabled = true;
    CreateContent();
private void CreateContent()
    // ViewModel associated with a specific RhinoDoc.RuntimeSerialNumber
    MyPluginViewModel = new MyPluginViewModel(DocUint, MyPluginController,
MyPluginDisplayConduit);
    // Set this panels DataContext, Page... panels will inherit this
    DataContext = MyPluginViewModel;
    // Bind this panel's content to the view model
    this.Bind(c => c.Content, MyPluginViewModel, m => m.Content);
private void ReloadContent()
    MyPluginViewModel = null;
    DataContext = null;
    CreateContent();
// Event that triggers from UI
    RhinoApp.WriteLine("MyPlugin language was changed...")
    ReloadContent();
What am I missing?
-Besties!
@oguzhankoral,
You’re setting your content from a binding on the Panel itself, which you shouldn’t add more than once. It may be getting a feedback loop from the multiple bindings you are adding (since bindings are two-way by default).
Try something like this:
Cheers!
@curtisw,
I am afraid to say that its same… :confused: DisplayConduit update itself according to new language but Eto controls like Labels, Button.Texts still English…
Do you have an idea to workaround this issue? I mean like, using different approach instead of binding this Content?
@oguzhankoral, sorry I can’t really say, I don’t know how your MyPluginViewModel works. Does it create a new UI for its content property? Typically you don’t create UI via the view model, but perhaps you have a reason for that such as changing the panel display completely based on certain conditions.
Perhaps take a look at how your MyPluginViewModel.Content property is implemented. Are you caching the UI that is created somewhere? It needs to be recreated.
@curtisw I followed the layout of Dale in the samples of rhinocommon. Maybe that structure not fits my needs. The structure of MyPluginViewModel is something like this;
internal class MyPluginViewModel : ViewModel
    public uint DocumentRuntimeSerialNumber { get; }
    public RhinoDoc Document => RhinoDoc.FromRuntimeSerialNumber(DocumentRuntimeSerialNumber);
    public MyPluginViewModel(uint documentRuntimeSerialNumber, IMyPluginController myPluginController, MyPluginDisplayConduit myPluginDisplayConduit)
        // Read-only property initialization
        DocumentRuntimeSerialNumber = documentRuntimeSerialNumber;
        // Panel
        Content = new MyPluginTabControl(this, myPluginController, myPluginDisplayConduit);
    private Control myPluginContent;
    /// <summary>
    /// Bind this to the main panel container contents, will get set by the
    /// next and back buttons (I dont have next back buttons)
    ////------> This part seems need to change,
    /// because I am using TabControl on the contrary of the Dale's example
    /// </summary>
    public Control Content
        get => myPluginContent;
        set
            if (myPluginContent == value)
                return;
            myPluginContent = value;
            RaisePropertyChanged(nameof(Content));
Cheers!
Hey @oguzhankoral,
Here’s a working sample of how to get this done.
The example you are working from is for a “wizard” interface which swaps out the panels for different steps. It can certainly do the same if really needed, but I kept things as simple as possible in this sample so you can see how it works. A more simple panel layout is here, which is what I based this on.
MultiLingualPanel.zip (31.5 KB)
Hope this helps!
Heyyo @curtisw,
This layout more simple and clear for me, it helps thanks a million :slight_smile: I encounter an issue, when I change the language again and again, the UI actions (even Rhino) getting slower each time. Is there any chance to we forgot to delete previous caches?
Perhaps you are hooking into events in Rhino each time you are creating your UI or creating multiple display conduits without destroying them? Otherwise there’s nothing (in my sample) that would cause that as far as I can tell.
@curtisw, You are right, I need to go hunting bugs…
Thanks for your patience so far, this discussion helped me a lot understanding of issues :slight_smile:
-Oğuzhan
