I’m trying to get a File3dm created in memory inside grasshopper, from a base64 string. There’s a File3dm.Decode
method in rhino3dm, but I’m not sure how to use rhino3dm within grasshopper.
Can this be done?
Can this be done?
If you are in Grasshopper, just use the RhinoCommon you already know.
– Dale
I’m not sure if I was looking at the same docs, because I was looking at https://developer.rhino3d.com/api/rhinocommon/rhino.fileio.file3dm. They look like they’re the same thing, but I wanted to mention it in case there are some differences.
I’ve tried a few things using that class, but I couldn’t get it working. Is there a working example of going from a base64 string to a File3dm object using python?
I forgot all the things I tried, but a few that I can recall are:
File3dm.FromByteArray(base64String)
File3dm.FromByteArray(bytes(base64String))
File3dm.FromByteArray(bytearray(base64String))
File3dm.FromByteArray([x for x in bytes(base64String)])
File3dm.FromByteArray([x for x in bytearray(base64String)])
None of them work, and the error they provide is some form of Expected Array[Bytes]
(or something similar, I can’t remember the exact error and I can’t access my work computer at the moment).
I’ve also tried saving a file with the byte array (instead of the base64) and loading it in a similar fashion, but I got some other errors.
Looking at rhino3dm.py, there’s a method called Decode
, but I’m not sure how to use rhino3dm.py within grasshopper. I’m also unsure if using Decode would work, since the docs say “[todo] add documentation”. I’m guessing it should work because I can use file3dm.encode()
from rhino3dm.js in my node server, from which I call rhinocompute. But so far it’s just a guess and I haven’t been able to test it.
A Base64 string is not the same as a byte array.
Can you explain in detail what you are trying to do and why?
Thanks,
– Dale
Try calling .decode('base64')
on your base64 encoded string and pass that off to the FromByteArray function
@dale Sure. I’m working on a web app where users can upload 3dm models, I send those models to a node server for further processing, and then I send the updated models to a rhinocompute server.
The way I send the models from the client to node is as a base64 string, since I’m sending more information with the requests and the body is a JSON. One of the JSON fields is the model
, which is the base64 string representation of the model.
When I call rhinocompute from the node server, I do the following to send the base64 string of the model:
const trees = []
const model = new RhinoCompute.Grasshopper.DataTree('base64Model')
const fileB64 = fileToBase64(file.toByteArray(options))
model.append([0], [fileB64])
trees.push(model)
const rhinoResult = await RhinoCompute.Grasshopper.evaluateDefinition(
definition,
trees
Then, on the grasshopper script, I grab the base64Model
string, and I want to generate a File3dm object from it.
I know a base64 string is not the same as a byte array, but I’ve tried everything I could think of.
@stevebaer I’ll try that, thanks!
