Live current selection in Revit and asynchronous solutions
Hi Andrew,
  1. Yes you can. Use the Graphical Element ‘Active Selection’
If the GH Definition is open you can have your script ‘Do Something’ when an item is selected.
Here i override the color of the Wall (and remove previous element overrides)
ChangeColor
Active Selection.gh (16.0 KB)
Alternatively you use this definition as a GH Player Script that would do it as a one-off when the button is pressed.
The transactional nature of Revit requires a command to complete before the next one is started, which requires the user who is interactively scripting to plan accordingly.
