Hey guys!
I have a simple question.
I have a list with two branches (indices 0 to 6). Now i want to reorder/create a list where the values of both 0 indices, both 1 indices etc. are in the same branch. How can i do this?
thank you! that’s exactly what i was looking for
Hey guys, i have another simple problem…i want to create a true false pattern out of two lists but everything i get is this:
how can i solve this problem?Don’t call it simple if you can’t do it!
Read this, esp. 3. Attach minimal versions of all the relevant files:
hi,
first of all, you can ‘internalise data’ so as not to need to upload the 3dm file…
secondly, you have in the first input 7 lists of varying lengths and in the second input 1 flat list of 17 entries…
even with the image it’s not clear (to me at least) what you are trying to compare…
some more explanation pls!
also: Jeder mag beethoven, aber nicht jeder spricht deutsch!
Hi aris! thanks your answer but minutes ago i found the solution…it was really simple, i just had to to compare two other lists
