is there some way to link a .ghcluster file with a relative filepath?
-Stefan
-Stefan
It seems that gh sometime āsearchā for the cluster on the same folder of current gh file⦠unclear to meā¦
This small c# script pick the first-found cluster on the same group and replace its path with the input string filename.
Cluster_path.gh (7.1 KB)
You can edit this to cover similar but different situationsā¦
Hope it helps!
Code:
using System.IO;
private void RunScript(string Cluster_File_Name, ref object Full_path)
bool searching = true;
string current_folder = Path.GetDirectoryName(this.GrasshopperDocument.FilePath) + @"\";
full_path = current_folder + Cluster_File_Name + ".ghcluster";
Full_path = full_path;
GH_Document ghdoc = this.GrasshopperDocument;
for (int i = 0; i < ghdoc.ObjectCount; i++){
IGH_DocumentObject obj = ghdoc.Objects[i];
string type = obj.Attributes.DocObject.ToString();
if(searching && type.Equals("Grasshopper.Kernel.Special.GH_Group")){
Grasshopper.Kernel.Special.GH_Group groupp = (Grasshopper.Kernel.Special.GH_Group) obj;
List<System.Guid> guids = groupp.ObjectIDs;
foreach(System.Guid guid in guids){
IGH_DocumentObject obj2 = this.GrasshopperDocument.FindObject(guid, true);
string type2 = obj2.Attributes.DocObject.ToString();
if(type2.Equals("Grasshopper.Kernel.Special.GH_Cluster")){
cluster = (Grasshopper.Kernel.Special.GH_Cluster) obj2;
this.GrasshopperDocument.ScheduleSolution(5, ReplaceCluster);
searching = false;
if(!searching) break;
// <Custom additional code>
public Grasshopper.Kernel.Special.GH_Cluster cluster;
public string full_path;
private void ReplaceCluster(GH_Document doc){
cluster.CreateFromFilePath(full_path);
Thats great, thanks a lot
Hi, could you tell me how to edit the link, if I want to have all my clusters in the same folder, for example, on desktop in C:\ drive, so I can use it in different .gh files. Thanks.
