Linetype "Model Unit" Broken? Not remembered?
When creating a new Linetype and checking ‘Use model units’, it seems that this parameter is not saved. Even if you go back and forth, clicking on other linetypes and replicating on the linetype concerned, the tick is disabled. Am I doing something wrong?
LinetypeModelUnit.3dm (3.7 MB)
SystemInfo.txt (4.6 KB)
Best,
Pip
Hi pip,
I gave this a go and the value toggle was working as expected.
Lets first try running the reset command and choose Restore Default Application Settings.
Hi Japhy,
Thanks for checking. I did, but there wasn’t much change..
But I realised that if I change the “width unit” at the same time, it allows the ‘model unit’ value to be applied.
See the video:
I reinstalled it completely as follows.
it’s still the same behaviour as in the last video. In order for the change to take place and for us to see the difference in scale in the layout, I have to make several manipulations for it to react.
Hi Pip -
Thanks. I’ve put that on the list as RH-87598 Linetype: Change Doesn’t Stick
RH-87598 is fixed in Rhino 8 Service Release 21
