Lines widths keep changing in Wireframe View
I’ve noticed that 2D line widths in Wireframe view keep changing randomly every 10–20 seconds. I’ve already restarted Rhino and tested it on different files, but the issue persists. The file size isn’t large, and I’m running Rhino on a MacBook M3 Max with 36GB of RAM.
Has anyone else experienced this? Any suggestions on how to fix it?
Hi Ondrej -
I haven’t heard about this behavior so far.
Does that mean that it doesn’t happen with a new file with just, e.g., a simple rectangle in a factory-default template?
Hello, thanks for your reply.
This issue occurs even with a new file. It seems to happen whenever the memory usage information appears in the bottom right corner. However, since almost no RAM is being used, it doesn’t seem related to that. It looks more like a graphical bug.
Could you please check if Rhino on your Mac has the same issue?
Thank you!
