Line Types
Is there any way to do “Lines” with something other than lines. I have lines that overlap a points and I need to have some way to show where they overlap. A thin line disappears under a thick line.
I don’t know what mean.
You can select them all and use Intersect, which will produce the intersections (points, curves) as geometry.
Do you mean in terms of rendering (in layouts)?
If so, you can for instance order them by depth. If you want some shorter lines to be rendered in front of longer ones that obfuscates them, use SendBackward or SendToBack on the latter. You can also use BringForward or BringToFront on the hidden segments.
If a “line” style could incorporate, say, diamonds, that would solve the problem.
Is this what you are looking for?
