We’ve been noticing a difference in behaviour between leader text created in Python vs. Rhinoscript with regard to maintaining the line separations. It’s probably best to watch these two screencasts.
First Rhinoscript:
http://screencast.com/t/HafXFZPbuzsJ
Notice how the format of the label (line separation and spacing) remains intact despite resizing the edit box. This is text string had the lines separated using VbCrLf.
Now look at how the Python version behaves:
http://screencast.com/t/kB1r8hWN2
This is a mess without even resizing the edit box. Resizing it goes from bad to worse. I’ve tried both \n and os.linesep in Python but the results are both the same, and the format of the label is lost as soon as the edit box appears. For what it’s worth, editing in the Properties pane is also a mess.
Is there a way in Python to achieve results closer to VB’s VbCrLf functionality? We need the format to withstand editing, as editing is a common occurrence on these types of labels.
Thanks,
Dan
