Hi everyone,
I am currently working on a Python script that enables me to create multiple layouts out of bounding curves and zooms the detail to each one of them. For some reason, the script only fails for the 1st curve on the list, not zooming in correctly. If you test for 1 curve (by only puttting on curve on the selection layer) the error becomes apparent.
import scriptcontext as sc
import Rhino
def AddLayout():
sc.doc.PageUnitSystem = Rhino.UnitSystem.Millimeters
page_views = sc.doc.Views.GetPageViews()
page_number = 1
if page_views: page_number = len(page_views) + 1
pageview = sc.doc.Views.AddPageView("A0_{0}".format(page_number), 34, 20)
if pageview:
top_left = Rhino.Geometry.Point2d(0,0)
bottom_right = Rhino.Geometry.Point2d(34, 20)
detail = pageview.AddDetailView("ModelView", top_left, bottom_right, Rhino.Display.DefinedViewportProjection.Top)
pageview.SetPageAsActive()
sc.doc.Views.ActiveView = pageview
if detail:
pageview.SetActiveDetail(detail.Id)
detail.Viewport.ZoomBoundingBox(bounding_box)
detail.DetailGeometry.SetScale(1, sc.doc.ModelUnitSystem, 1, sc.doc.PageUnitSystem)
detail.DetailGeometry.IsProjectionLocked = True
detail.CommitChanges()
sc.doc.Views.Redraw()
layer = rs.GetLayer("Select Layer", None, False)
ids = rs.ObjectsByLayer(layer)
for id in ids:
bounding_box = rs.coerceboundingbox(rs.BoundingBox(id))
AddLayout()
This is the first layout (WRONG)
This is the second one and all that follow (RIGHT)
I leave my test file for anyone that wants to try. CatalogueExample04.3dm (163.5 KB)
