Layers in Rhino.FileIO.File3dm
I’m trying to save (i.e. some geometry created with a python scipt) to different new Rhino-files, each with a different layer structure and file settings.
I started off with FileIO.File3dm class, and found it difficult to navigate around the layers.
FileIO.File3dm.Layer returns something of type Rhino.FileIO.File3dmLayerTable (no documentation http://4.rhino3d.com/5/rhinocommon/ ?) which seems to be different from Rhino.DocObjects.Tables.LayerTable.
How does one retrieve Layers in this File3dmLayerTable?
Is there a smarter way to achieve the goal maybe?
It might be a unvalid point, but are you writing this in python?
Edit : have you looked here : http://4.rhino3d.com/5/rhinocommon/html/P_Rhino_FileIO_File3dm_Layers.htm
Yes, it’s in python. Is there a way of transforming a IList into a (python) list?
Is this what you want?
layers = rs.LayerNames()
if layers:
    for layer in layers: print layer
Nope. The File3dm object is not the ActiveDoc.
I’m intending to manipulate it “in background”, without opening it.
If it was, I could have used RhinoDoc.Layers (I guess).
oh i see. let me see what i can do! =)
guessing i can just create a 3dm file and use it since you only want layernames right?
See if this works, save script with the 3dm file you want to read.
import Rhino
def main():
    path = "layer.3dm"
    f3dm = Rhino.FileIO.File3dm.Read(path)
    layerlist = f3dm.Layers
    if layerlist:
        for layer in layerlist: print layer
main()
This works! Thanks!
Why is the same thing (addressing Layers as a list) not working below?
The idea is to create the layers “on the go”, depending on what elements will be written to which file, instead of reading a layer structure from a template file upfront.
def main():
    #create a 3dm file:
    f3dm=Rhino.FileIO.File3dm()
    #add objects to f3dm to a specified layer (first check if layer already exists, if not, create a new one).....
    #create new layers:
    newlayer=Rhino.DocObjects.Layer()
    newlayer.Name="abc"
    newlayer.Color=System.Drawing.Color.FromArgb(1,180,203,63)
    f3dm.Layers.Add(newlayer)
    if layerlist:
        for layer in layerlist: print layer #<< I get an error here, the rest works.
    #save file:
    path=r"Z:\test\test.3dm"
    f3dm.Write(path,5)
no layers are added, so layerlist is empty.
i have limited experience with this kind of manipulation, i will look into it later :wink:
-Eivind
try adding this
    f3dm.Polish()
f3dm.Polish() does the job. Many thanks!
No problem!
