Does a script exist for extracting the names of all layers in Rhino .3dm files; those that exist by default and those that are created by the user? If I were to attempt to write such a script, what reference should I consult to know which variables to query?
Thanks.
David
Rhino.LayerNames() (vb) or rhinoscriptsyntax.LayerNames() (python) will get you the names of all the layers in an open document. Or do you want to read an unopened 3dm file?
Layers that exist by default are contained in the template files and those can vary, there is no set standard.
–Mitch
Thanks, Mitch.
I’ll be trying in in python.
Iterating through all the files in a directory, opening them only if it was necessary would be my guess, using a routine for stepping through all the files in a directory, something like what Pascal shared with me about resetting visibility of all files in a directory:
BatchRestoreAllVisibility.py
Hi David,
to get the layer names you have to read the file even when not opening it in Rhino. This can take as long as it takes to open the file. Below is an example to start from:
import glob
import Rhino
import scriptcontext
def ListLayersInFiles():
mydirectory = "C:/Users/UserName/Desktop"
rhino_files = glob.glob(mydirectory + "/*.3dm")
if len(rhino_files) == 0: return
for filename in rhino_files:
if scriptcontext.escape_test(False): return
f = Rhino.FileIO.File3dm.Read(filename)
if not f:
print "Error reading file:", filename
else:
print "Layers in: {}".format(filename)
for layer in f.Layers:
print " ", layer.Name
print ""
ListLayersInFiles()
@stevebaer, i’ve found that if i want to print layer.FullPath
instead of layer.Name
it does not work, so i tried this instead:
rs.LayerName(layer.Id, fullpath=True)
but it gives an error not finding the provided Id
, maybe because it is calling __getLayer
using scriptcontext.doc.Layers.Find
which seems to be bound to the current document. Is there a way to print the full path in above example ?
thanks,
c.
Awesome! Thank you.
David
I’ll have to investigate what is causing the FullPath to fail. I’ve logged this at
https://mcneel.myjetbrains.com/youtrack/issue/RH-37253
Thanks
