In 3LevelDeepRef.zip (56.7 KB),
D.3dm is referenced in C.3dm with a linked definition and a reference layer style. C.3dm is referenced similar in B.3dm, which is referenced similar in A.3dm.
In V5’s Layers panel:
V6:
When this script is run in V5 and V6:
layers = rs.LayerNames()
if layers:
for layer in layers:
print rs.IsLayer(layer), layer
V5’s rs.IsLayer() recognizes all the layer names returned by rs.LayerNames():
True Default
True UniqueLayerNameInA
True B.3dm
True B.3dm::Default
True B.3dm::UniqueLayerNameInB
True C.3dm
True C.3dm::Default
True C.3dm::UniqueLayerNameInC
True D.3dm
True D.3dm::Default
True D.3dm::UniqueLayerNameInD
Whereas V6 doesn’t with layer names in sub-nested references:
True Default
True B.3dm
True B.3dm::Default
True C.3dm B.3dm : C
False C.3dm B.3dm : C::Default
False C.3dm B.3dm : C::UniqueLayerNameInC
True D.3dm B.3dm : C.3dm : B.3dm : D
False D.3dm B.3dm : C.3dm : B.3dm : D::Default
False D.3dm B.3dm : C.3dm : B.3dm : D::UniqueLayerNameInD
This problem doesn’t occur when the ID’s of the layers are used instead of their names:
layers = rs.LayerIds()
Thank you,
Steve
