Layer filter - right click to activate just one filter
Hi McNeel
In Osnap and Selection filters (and maybe even other places) we can right click to activate just one filter (and even use Shift to make it one-shot). Would it be possible to implement the same for the layer filters?
Say I want to go to showing all layers that are locked on the above screen grab, I have to first click Filter, then All Layers, then Filter again (since it disappears every time I change a filter) and then “re-apply” Locked Layers. That’s a lot of clicks for something that simple.
A simple solution could be to allow mutiple selections with Shift as the modifier, allowing us to select and deselect multiple filters as long as Shift is pressed. Not exactly the same as Osnap and Selection filters, but still… :slight_smile:
TIA, Jakob
Hi Jakob -
Enhancement request: RH-77216 Layer: Filter - RMB to activate single option
RH-77216 is fixed in Rhino 8 Service Release 13
