Maybe this is a very basic question, but I’ve spent already many hours and can’t find a solution.
My challenge is to simply get the UTM position of a point that I know the LAT and LONG. Actually I have already defined in my Rhino file that 0,0,0 would correspond to that EARTHPOINTCOORDINATE.
But at some time in the future somebody will ask that in UTM. I can use a simple online calculator, but I guess it is possible in Grasshopper, but I have not find it.
Hi @mutarq,
Heron has a Coordinate Transformation component that will convert a point from one coordinate system to another. You could construct a point from those lat/lon values and use the component to get UTM coordinates.
I can post an example when I get back to my machine next week.
Thank you for replying! and of course next week would be ok… hope ther is an easier solution. But I’l try too the python Transfomer suggested by @dn.aur
Hi @mutarq ,
This is the set up for using Coordinate Transformation. You had two slightly different sets of coordinates in your original post, so I’m showing both.
Hello Brian ! im having some trouble with while reading some coordinates ….i have set the earth anchor point on rhino and then when puting a point on the 0,0,0 it should match, but it doesnt do you have any recomendations?
When I use the WorldXY as input to XYtoDD component, the output matches the input to SetEAP. Neither point 105 or 106 XYtoDD outputs match the SetEAP input in your definition. Can you confirm one of those points is actually 0,0,0?
this is the correct position but when i try to use this LON AND LAT for the earth anchor point and then to check the UTM to confirm…the UTM is different . i need some help !
Is there a way to use the UTM as earth anchor point?
