I don’t understand your problem. You seems to know the 2 classical methods, offset and scale.
You can adjust each of these method with the curves length, area …
Hello Laurent,
Thank you very much!! Is actually logical.
When you sit over such a problem for so long, you sometimes lose track of things.
Sorry that I bothered you with this.
Got something good with me!
greeting
Theo
You are welcome, you have done very nice portraits.
You are lucky to have a laser cutter, I wait to have one near my home at the FabLab. But as the Fablab has no room, no Laser Cutter at the moment. I want to make puzzle so I’ll need to test cutting wood with pictures glued on a face (which paper, which glue …). So I’ll gave many test to make.
Hello Laurent,
would like to support you if you were around.
Maybe there is what I can do for you despite the distance.
You have to show me that with the puzzle, sounds interesting. I still have work to do on my portraits; Letolap’s have set the bar pretty high.
So if I can do something, I have a carpentry shop, if you need a tip or something else, just get in touch.
I’m not in the forum that often, so feel free to email me directly.
regards
Theo
Can you give your email id?
how can we give thickness to the lines
please help
Hello
Begging is not useful. Just read the discussion. You will find the answer of your question.
i already read but couldnt find a proper solution
Hello
so you read it and you say it isn’t a proper solution without giving any explanation !!! Nobody here has a Crystal Ball to read in your mind. So please post a picture of your problem and also a script. There are many helpers on this forum but you have to formulate a clear question. I gave two (2) ways of making a thickness.
dali new gh.gh (760.0 KB)
can you help me with the offset thing
can anyone check where am I wrong
Hello
here are 2 ways,
Offset using Clipper plugin (more reliable than Legacy GH/RH Offset)
With scale
dali new gh LD.gh (752.2 KB)
I still don’t really understand why you choose to not follow examples and recommendation already provided!!!
looks like @Gijs ! (but he has way better hair…)
LOL that’s the first time I hear my hair being mentioned in one sentence with a comparative of good
consider the source…
