Largest possible rectangle inside closed curve
Hi All,
Am trying to get a continued answer to the below forum:
I also have a problem and cannot get the C# component to work inside grasshopper.
Are there any other similar forums?
Thank you!
That’s strange: what exactly is the issue?
BTW: if the Curve is convex [or the derived Polyline - within some reasonable accuracy - is convex] there’s tons of papers/threads around.
BTW: this is the best approach (as described in the paper - Note: algorithm is O(N^3) ) so far:
Hi There!
This is the error that i get
Well … I do hope that you know(*) how to load dll’s. Like (playing with ShapeOp):
(*) In case that you don’t search around with appropriate keywords.See this as well:
Other than that Laurent’s thingy has certainly potential (a thing or two is required, mind like get rid of the rect cent pt):
Dag Emma -
Could you upload your gh file? Make sure to internalize Rhino geometry in the Curve component.
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Well … I did a big U turn:
  1. “Pixelize” the Curve in a nullable DataTree (of type Rectangle3d).
  2. By doing so get a Matrix [Rows=yRes, Columns=xRes] as well [0: null / 1: Rectangle3d];
  3. Get the max Rectangle in the Matrix (that’s very easy and real-time fast: classic Matrix stuff).
Expected Elapsed time for some reasonable x/y res: 10 milliseconds max.
More after the Spanish MotoGP
Dag Wim en badankt!
Rhino 7 SR15 2022-2-8 (Rhino 7, 7.15.22039.13001, Git hash:master @ 2833e18992fc4b5cf99bb29c4d8e8add4f02074d)
License type: Commercial, build 2022-02-08
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon Pro WX 3200 Series (AMD) Memory: 4GB, Driver date: 9-7-2021 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.30.18 30.0.13018.2
> Accelerated graphics device with 6 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 4-3-2022 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 9-7-2021
Driver Version: 30.0.13018.2
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.15.22039.13001
C:\Users\emma.dehaan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
largestrectangleinconvexpolyipopt.gh (6.7 KB)
Update (MotoGP FP2 was pathetic … and I hate Fabio):
If we combine this (Existed C#: Real-time Matrix max rect “area”):
With this (WIP : testing some // stuff for less milliseconds - shown very low Resolutions for inspecting the Matrix values):
The problem is rather solved. But is the 10 milliseconds goal achievable? (Rotations as shown [and a bounce solver] are obviously required). That’s the big question.
More after the Qualifying (Forza Ducati) tomorrow.
I try this , every point on the curve have many possibilities.
Maybe the idea with scripting work faster
The solution with the blue 'x’s seem to work! Would it be possible to share this script?
Thank you so much!
Dear Peter,
I am currently working on the same issue that is solved by your solution here.
Would it be possible to share the C# script that determines the max rectangular submatrix?
Thank you!
Well … I’m 1M miles away from base (summer windsurfing period not ended - more is more). When I’ll be back (when? you tell me) I’ll see what I can do on that matter.
Here is one solution, brute-forse approach with precision determined by grid resolution. Curve should be closed and placed in XY plane.
  1. Grid resolution is defined by number of points (gridAxisCount) along longest axis of BoundingBox of closed curve.
  2. Grid resolution is calculated as
    input:
    • curve
    • gridAxisCount
      result:
      gridResolution = Math.Max(bbox.Max.X - bbox.Min.X, bbox.Max.Y - bbox.Min.Y) / gridAxisCount;
  3. Bounding box of curve is now filled with grid/(matrix)/(rectangular array) of Points where x and y distance of points = gridResolution.
  4. For each Point_i in grid (Bounding box) we try to construct rectangle where Rectangle.Min = Point_i and Rectangle_i.Max is one of another point inside grid …
  5. Such rectangles have edges parallel with x and y axis, we keep information about the largest rectangle
    Now we rotate curve around AreaCentroid for given angle and perform tasks 1.-5. for each new rotated curve.
    Totalangle (TotalAngle) should be kept at value of 90 degrees, angle count is number of iterations.
    At the end we check for which angle we get largest rectangle, and return it as result:
    = largest rectangle (by area) for given gridResolution and given number of angle iterations
    MaxRectangleInsideCurve.gh (13.1 KB)
Works perfectly well. Thank you! Very useful!
Just wanted to say a huge thank you to all in this thread - the info in here was very helpful!
I’ve just finished implementing this for our CNC machines to turn TextDots into the Largest Text possible.
I couldn’t use anything directly as I have additional constraints but the methods were useful to explore as I implemented.
I like the search approach by @anon39580149 but I am constrained to look for axis Aligned rectangles for legibility and printing with industrial inkjets.
I explored the Pole of Inaccessibility method but I need to find space for rectangles of a certain aspect ratio rather than a circle. While I could adjust that method to suit I don’t think this would preserve the same optimality & convergence guarantee.
Specifically, this is because it would be hard to find a method which for a given test area rectangle finds a good upper bound on the largest possible which includes the test rectangle - the pole of inaccessibility works because the algorithm relies on the point being within the test rectangle and the distance to the nearest boundary segment being a good upper bound.
I ended up using the Grid test method similar to @PeterFotiadis to make it more efficient i added recursive subdivision. I’d prefer to use a priority queue to cull bad areas to test but to do that I’d need the heuristic described.
Input
Searching for clear areas using recursive subdivision.
Result
And yet you have no code to post :question: :roll_eyes: :-1:
OpenNest has inscribed circle if needed, I use it mostly to write text tags on 2D elements:
interesting read. But other then annotation, what could be are other possible use-cases?
