Large Deformation Analysis
When I use the large deformation analysis and try to calculate the buckling factor I get the error message ‘1. The model has no second order forces NII defined for which a buckling load factor could be computed.’ How do I address this? Many thank
Hi you should first use the Analyze Theory 2 component first: 3.6.2: AnalyzeThII | Karamba3D v3 and then you can calculate the Buckling Factor
