Language mix in recent commands
Right-click into the command area shows the recent commands menu.
It presents a mix of German and English command names.
Like Emap / Umgebungstextur etc.
The wish is of course the same language for all commands.
At best in German if Rhino runs in German.
@Joachim_Kuntz perhaps?
Which languages do you have loaded on your PC?
I tried installing the English version of rhino on a device that only had German set as system language yesterday and it glitched out (some plugin error messages and German labeling despite using the English installer) until I reinstalled it with both English and German as system languages.
No idea if that helps with your specific problem though
OS in German
Rhino WIP comes naturally in all languages.
The used language is German.
I think the language mix is a general problem = a bug.
@Gijs perhaps, for the UI cleanup round?
I’d be glad if this issue would get some attention!
If it can’t be resolved, the right-click function in the command area should be removed.
At least in non-English UI.
As it is now, it’s only a source for confusion.
