I am trying to understand what is the knot osnap is for. I though that is was the edit point (not the control point). however knot osnap doesn’t always snap to the edit point and snap on the curve on a random place on the curve.
So are knot and edit point not the same? and if not how to display them?
Hi Paul - knots and edit points are not the same - currently the only way to see knot locations on a curve is with the InsertKnot and RemoveKnot commands. Some curves (single span) will only have knots at the ends.
Hi Paul - it is certainly less commonly used, but if you, for example, split a curve exactly on a knot, then the resulting curves will be simpler and cleaner than if you miss by just a little.
