This is my study case about kinetic facade via Grasshopper Algorithm .
1- Create a flat surface then divide it by triangles.
2- Explode all cells to be able to control points as lists.
3- Divide Each cell into three parts by creating polygon curves from those point lists then rotate its around its’ edge axes .
4- finally create boundary surfaces.
you can mimic that from an algorithm here : http://bit.ly/3nZ2MEV
