I’m new in the Karamba Gh workflow. My issue is everytime I plug Assemble to Analysis component, it crashes with the latest karamba version 2.2. At the begining I thought it was because of the RH version being not updated one. So I updated rh7 to the latest one RH7 SR29, but the crachs go on.
I’ve never encountered this. Is there a solution to that?
Hi, the script works fine when I connect it. However i do notice that you are using a much older version of Karamba. Did you make sure to download and install the latest version? The latest version is 2.2.0.18
I’m trying to solve the problem by different version, the thing is in th eold version, the shell view won’t work, in the new version, the analysis part crashes when connected.
Perhaps I should try the save mode… or rh6. It’s kind of crazy I have to say
