this is a basic question regarding joining poly surfaces, could you please explain why this object cannot be joined into one poly-surface. thank you
join.3dm (398.3 KB)
thank you for you reply, any suggestions to create the same shape without having to join 3 edges?
As @DiegoKrause said you have nonmanifold object and if you move & try to join you will get these issues.
Cheers,
BVR
what’s the objetive? you can group those objects if you want to move them together
hmm, wouldn’t that be a problem in case of 3D printing?
yes but having only that is not clear what you want or why you need that geometry in that way
Thank you
