Join Pieces of a Parametric Lamp to a Single Closed BRep
hello! i need some help in this… i am trying to create a parametric lamp this is what I had created using grasshopper, they are indivdual pieces.. I am curious if there is a way where I can create joints (on the grasshopper) to joint to a ring, something that I have cad for a example.
I am also not sure why one of the panel is not offset?
lamp joint.gh (18.7 KB)
I don’t know if this solution will work but I would put a small cylinder on top.
Your intention is unclear. You want to create joints (of what kind?) to joint (join or joint?) to a ring (join or joint what to the ring?).
I wanted to design a joint mechanism that connects the individual white pieces to brown, which will house a light at the bottom. The white pieces must be 3D-printed separately rather than as a single structure, so the joint should allow them to be securely assembled while maintaining the overall design.
I’ve printed things like that before. Here’s how I tweaked yours to get this:
I don’t have Pufferfish but didn’t need it for this because I do have Sasquatch primarily because it has an OffsetBrep component that has a built in Thicken option that I use a lot.
But you can get around that by using the GH version of Offset, do you own Offset, and the use the resulting edges to make Ruled surfaces that connect the 2 Brep surfaces.
Here’s my tweaked version of your file that won’t work unless you either add the parts I described above to replace the white box , or alternatively install the Sasquatch add-on.
lamp joint-bb1.gh (32.9 KB)
But jointed how? Hinged radially, so that it opens like a flower, or in some other way?
