Join Edges of a Polysurface
Using joinedge command I can join two nearby edges, selecting edges one by one which is tiresome in many cases.
Is there any way to join all close edges [within a range] without selecting the close edges of one or many poly surfaces?
typically speaking you do not want to force edges that don’t want to join. The only way to do so is fudging the tolerances and that will 100% cause you downstream data transfer problems.
the best way to fix it, is to just fix it.
check this video-
