Join curves issue
I am trying to join curves of two surfaces to create a closed loop, I have used this method in the past and it worked well. For some reason it does not work this time. Trying to understand why.
Attached grasshopper script
water_drop_pattern.gh (13 KB)
Trying to create this closed loop wall.
Join curves joins curves that have endpoints touching. Your curves aren’t touching.
Some options. Surface or line.
I understand my mistake now, I needed to flatten the curve
I understand my mistake now, I needed to flatten the curve on the join curve command
