Hey All, i had tried to join these curves into a single loop. What will be your recommendation to do so?
CurveJoin.gh (20.2 KB)
Any reason you are working 2,221,232.403 units away from the origin?
Anyway if you put your curves in the correct order and direction you can use the connect curves component.
That is due to stringline given by my colleagues. Is there any way to sort curve to be in a loop order ?
I bring in the Connect node and it gives me this, any reason why?
Alright. Cheers, mate!
