Issues with latest R8 and D5 render
Hi @Japhy,
Thank you so much for sending the versions. I have been running through the different updates and during testing for about 1,5 hours. I have for each version opened two different rhino files and launched one of them into D5. After it has been launched i have been spining the model(like when working in 3D) for a while to check what happens.
Here are the results:
Rhino - 8.5: Working
Rhino - 8.6: Working
Rhino - 8.7: Working
Rhino - 8.8: Running out of memory after about 5 min of working, and crashing.
Rhino - 8.9: Running out of memory after about 5 min of working, and crashing.
Rhino - 8.10: Running out of memory after about 5 min of working, and crashing.
Rhino - 8.11: Left my PC for about 8 min while Lauhing d5, when i came back it had an error saying I was out of graphic memory and crashed.
So from 8.8 my pc is using A lot more VRAM. It keeps building up the ram usage until it crashes after 5 min, even if i just leave the pc it will keep building up the ram usage and eventually crash.
I hope this is a help for you to finguring out the problem :slight_smile:
