Issues with InstantAlias
the JJ alias kicks of instantly typing J which is not an alias
also similar, when i have an alias set to BS for BlendSrf while also having b for the one shot snap between (which is also not set to instant), it fortunately does not try b first but finishing typing BS it triggers b instead again.
further
the delay in the settings does not seem to correspond with the settings in the ToggleInstantAliases command which seems to be the only one that actually takes the changes into account while they are ignored in the settings.
also, when i toggle the instant alias and try ö for instance which i have set to line it repeats ToggleInstantAliases.
the entire experience is unusable at the moment while in v8 that does seem to be an issue, though i dont have any delay that i can set but i do not use that anyway, did maybe delay trigger these complications?
I reported something similar months ago.
well i understand that @stevebaer had a good flow implementing it but is probably busy with many other things right now, i just hope he will come back to it again before v9 is released hopefully even soon, i really love that speedy swift response the instant aliases bring along.
Yeah, it is far from being production-ready in its current state (at least on macOS).
Steve’s was out recently. He’ll definitely be back on this. I’ll go ahead and log these reports so we make sure they don’t slip through the cracks. RH-84757
thanks @Trav the issues are similar enough that they might envelope in fact the same issue, but to be sure if you could add a link to this description or topic either just in case.
