Issues import urllib2 into Grasshopper
Let’s take this to a separate topic.
@alain can you see if you can reproduce this behavior? Is this a regression from Rhino 5 for Mac?
@dan,
Importing the package is not a problem although getting what I want out of it is not immediately obvious.
I get make a request to a local server:
import urllib2
req = urllib2.Request('http://localhost:8000')
print dir(req)
response = urllib2.urlopen(req)
html = response.read()
print html
but if I try to access a remote site like developer.rhino3d.com I get:
the authentication or decryption has failed that I think has to do with all sites being now encrypted? Is that what the user is experiencing?
hi @Alain:
I’m the user in question – following this closely because I use a lot of python in Grasshopper in my day-to-day work, and making API requests is particularly important.
Here’s what I’m seeing on my end:
Commenting out that import clears up the issue:
Just to be clear I’m using the Version 6 WIP (6.15.19092.12046, 2019-04-02). Are there any other debugging tools or ways to shed light on the details of the error that I may not know about that would be helpful to pass along?
Hi Carsten,
Issue has been logged and I’ll look at it as soon as I can.
Thank you for reporting,
Alain
Thanks!
This issue should be fixed in the latest RhinoWIP. Please test your imports and make sure.
Looking good on urllib2! Thanks
